Crankcase dowel pins
Status
Not open for further replies.
Steveng
I have found out the hard way that the dowel pins that center the main bearings have been pushed down into the block. I can get new ones from a local parts house, but what is the best way to remove the old ones. Do I drill them out, can I heat the surrounding metal and somehow pull them out? Also while reading the manual about the connecting rods, it calls for a special fixture to install the rod caps. Is this just recommended or is it a must.:confused:
91 70hp. johnson outboard
oldcatamount
Re: Crankcase dowel pins
You will need to drill the pins out. I'm actually surprised that they could be pushed down into the block. Are you sure they are pushed down or are they broken off?
JasonAych
Drill down center of pin, thread something in tight, then pull it out?? Haven't had to do that yet but that is what i would think to do.
JasonAych
When I say drill i mean smaller than the dowl so you don't hurt anything.
boobie
If you have an OEM manual they show you how to make a special tool to remove them. They are removed from the cyl side towards the intake manifold. I've always been lazy and didn't make the tool. I just drove the pins out in the correct direction with a "long" punch being careful not to damage the block. I'd rather do this than to try and drill them.
Steveng
Thats what I thought, but do to the luck I have drilling out broken bolts, I decided to take it to the machine shop and have them do it.
Thanks, Steve
Dhadley
Boobie is talking about the pins that locate the front crankcase half. I beleive you are talking about the pins that locate the center main bearings for the crank. If so, they are very easy to remove. Just drill a small ole in them and start a sheet metal screw into one. Now you have something to grab. They'll come out using a pair of pliers. No big deal at all.
boobie
My mistake. Next time I'll read the post a little closer. Sorry.
Dhadley
No problem, you bring up a real good point. We've seen some good blocks ruined because someone did not understand those are tapered pins and need to come out toward the intake.
i57chevy
do we know how the main bearing dowel was eventually removed and/or pulled out?
Status
