Ran good last year, this year as I'm tuning it up, replacing fluids and the like - the lower unit isn't shifting into gear. SOMETIMES it will shift into reverse, if I jimmy the prop a bit, and shift with the engine off - then it's stuck in reverse - the lever won't shift it back to neutral.
Normally, when its shifting, I feel the clunk as it goes into gear - when the engine is running, it's all free flowing - I don't feel any clunk.
With the hood off, I can see the cables are doing work - it's moving levers and turning things on the side of the hood - but it's just not shifting into gears.
Any ideas?
Any ideas?
