Texasmark
- Dec 20, 2005
- 14,891
Re: 1989 Mariner 75 HP 3 Cyl - bogging no acceleration believe its a spark issue
Read your header/post title and then these words. The 3 cyl has 3 cylinders and a CDM for each plug and I have replaced one on my engine, so they can and do fail and when they do, your engine idles fine, but when you punch outta-da-hole, it just wobbles and bogs. Just because your DVA said that you were getting voltage (under those measurement conditions), that may not be the case when you hole out. You could have 2 problems, the stator corrosion on #1 or 3 and a bad CDM on 3 or 1.
One more question. I have two ignition coils (coil packs) for four cylinders. Coil #1 powers cylinders 2 & 3 and the second powers 1 & 4. I'm going to switch them and that should tell me if either is bad. My question is do I switch the input voltages also or do I leave the inputs in the original order. I would think if I switched the inputs it would screw up the firing order.
Thanks.
