gm280
- Jun 26, 2011
- 14,605
A little more sanding today. I have a little over half the hull sanded now. And it is coming out nicely. I still have some pin holes to fill and some low areas as well. But all in all not too bad. This initial primer coat is now my first guide coat to go by. And it will tell you easily where the low areas are. Lots of time, you can't fill the low areas with you hands, but you can see them with contrasting colors. And that is how guide coat works.
Easy to see the high areas. I really like how the contour of the keel came out. That was totally busted up when the PO hit something really bad and hard.
The side and part of the bottom with the cross-hatch sanding. It looks bad, but it is really smooth and nice. I do like how the primer sands.
Here are those two areas that I had to grind out and fill and sand. I know from the picture they really look bad, but they are extremely smooth and very solid. The next primer coat will make them look perfect.
The transom really came out pretty flat. A few high areas but basically not too bad. The irregular transom top area (the lower section in the picture) will be cleaned up before I install the metal piece across it. It looks lope-side in the picture but it will look clean and blocked off straight. Some of the irregular look is the filler I extended below the transom itself to get everything to the same level. The left side section in this picture is more how the actual transom will look.
The darker gray area in this picture is a low area that will be filled. Easy to see once you sand.
And finally some remaining pin holes I still have to deal with. Yes even with a high build thick primer coat, the pin holes are still showing in some places. That is proof that if you think paint will cover over such things like pin holes, scratch marks and things like that, you would be wrong. If thick primer won't cover over pin holes, paint certainly will not. So if you can feel any imperfection or just see one, it will still be there after you paint if you don't take care of it during the prep work. You can't hope thing will cover over, you have to fix them. And that is why everybody says, the prep work is the most time consuming of any paint job. The better you do the prep, the better the finish will be.
Until next time, you all have a very nice day.
