GilligansIsland
- Apr 14, 2010
- 138
Re: Can it be done?...Adding a FULL / COMPLETE closed cooling system on a Volvo I/O
Thanks, but I'm asking about your application. As far as I know, if you go with aftermarket mans/risers that are ported and likely using a ported spacer, you will run into alignment issues with the Y pipe. There are other concerns that you will have that I will not, and I'm wondering just what you did or are going to do to make this work.
Thanks.
By porting do you mean adding the water connections for Full cooling? If so most replacements have ports for just about every possible use.
Try these people "http://www.ebasicpower.com/c/IND/Indmar%20Inboards"
You will need manifolds, spacers to install your fresh water inlets for the risers and of course block off plates between the manifolds and the spacers.
You can by elbows and pipe from West Marine and other places to get it hooked up.
Seen to have problems posting hope this goes through.
Thanks.
