I have 99 Volvo SX drive and have a very slight vibration while straight ahead and a fairly large one when the drive is turned right of left with power applied. The U joints are new and the gimble seems totally OK. When I did the Ujoints it actually seems to make it slightly worse. Yikes. I read a tech bulletin and I might have screwed up the orientation of the center yoke relative to the others. I might try to flip it and see if it changes anything. I have tried 2 props and have had one rebuilt so I am sure it is not prop related. I checked the alignment and it seems OK too. I can slide the tool in and out pretty easy and the grease from the coupler splines are uniform. I don't really have abaseline for what the alignment tool is suppose tro feel like though, since I just bought it. ( I don't think alignment can cause vibration anyhow......just kills couplers...correct?) I am replacing the gimble bearing anyhow since it apart and while doing that I noticed the drive shaft that engages the coupler has some wear where it slides through the gimble bearing. It looks like a typical surface hardened thing that has the upper layer hurt, slight pitting and granular looking. It looks worse as you get farther away from the o-rings. Is that where it rides thru the gimble bearing while you turn since the axis is rotation is outward? I measured it and it is about 1.3755 inch. My aligment tool is 1.3745 so I think the shaft is OK. One other piece of info, both the little o-rings were quite beat up. I assume that are for grease retention only and have no effect on side clearance. True? Anyone have any clue what might have caused the shaft to wear in the first place? Think this is the cause of my vibration? I hate to throw a 200 dollar part at it and have same issue. Am I just being too anal about the vibration and expecting it to be totaly vibe free while turning under power? Thoughts?
