Hey wood, put this to rest for me, do you have a way of making a PL fillet "not" bubble? I may have miss quoted you and want to set the record straight. I tried the ole paint thinner trick and it did smooth them out, but as soon as i turned my back the bubbles returned and gave me the finger!its really not a big deal but if you got something up your sleeve, please share
Yeah! kinda like Master KanNice fillets . . . you are the master of fillets..
Thank you so much, now I understand. Also, while were on this subject, is it ok not to overlap my 1708 at the top of the stringer? The reason I ask is because my stringers are so short, theres not a lot of room to work with.What I'm saying about the cleats is this...If you run the 1708 tabbing to the top of the stringer and stop without rounding it over and then place the 2x2 cleats on either one side or both sides then you could just lay a strip of CSM on top to seal em off. There's really no need to go over the top unless you really feel the need. Douglass Fir is an excellent wood to use for the Cleats. If You soak it with My Old Timers Sealer It'll Never rot.
