I can't believe how nice that came out in the wash. A little more clean up and you'll be set. That brass pipe fitting comes out easy enough. Shouldn't be to tough to turn as long as your socket fits it well.
I can't wait to see it with paint.
Hey Rick, I had a small set back. I really wanted to leave the ring but I just could'nt. I had to take it off. Its very doable with the ring on but I could'nt prep the way I wanted to and grease from the swivel shaft and swivel pin kept reappearing
I'd wipe it off and 5 minutes later it would be back, with friends! :facepalm:
Mostly I was just feeling guilty
so I snatched the ring off. Was'nt that bad, tho the bottom swivel pin did kinda give me the blues. But in the end it came out :bounce:
I have to power wash again, scotch brite one more time, acetone, tape off everything, light mist the bear metal with etching primer, shoot primer, maybe hit it with 220 then paint. I cant wait to see it painted either!!! Especially the shark bite repair on the gear housing
