Mercruiser 5.0 mpi bravo help with wiring needed
Bennettrj
Hi there I'm new too forum and am in need of advice I have a mercruiser engine listed above it is complete and was running until I removed it from boat hull too fit y pipe as original owner had thru hull exhausts. But whilst engine was out of boat the goats in the field have chewed. The harness wired too engine including ht leads. I am looking for a detailed wiring harness diagram too help me out any help greatly appreciated thanks in advance
thumpar
Re: Mercruiser 5.0 mpi bravo help with wiring needed
The manuals can be found in the adults only thread. Post up a serial number so we know what you have.
alldodge
:welcome: to iboats
The easiest way would be to pick up another complete harness and if you have the engine serial number we could figure it out. If you want to patch what you have we could still use the serial number or at least a year of the motor.
Below is a generic manual with wiring
http://www.boatfix.com/merc/techbk/96/96hgd4.pdf
Bennettrj
I have just ventured out in the dark and got these numbers from the engine the are printed on stickers like barcodes on the bell housing. They read
5.0 Efi bravo 4m32027n1. On one sticker and
Serial no. om081308 on the other sticker does this help??? thanks rob
alldodge
The EFI harness part number is 861157T 1
The engine harness number is 862179T 1 (Delco alternator) or 861819T 1 (Mando alternator)
The EFI harness is around $500 using google search mercruiser 861157T1
Engine harness is around $100 using google search mercruiser 862179T1
Do some looking around and maybe call the dealer to see what they would want for it.
Bennettrj
Mercruiser 5.0 efi
I desperately need a wiring diagram for above engine as loom is badly damaged I have been told there are two wiring harnesses available depending on which alternator delco or ????? But mine says mercruiser 862031 ?????so have no IDea. Really I'm after a wiring diagram and a part number for replacement engine wiring harness. Many thanks in advance rob
Bennettrj
Serial number in engine is 5.0 Efi bravo 4m32027n1. On one sticker and Serial no. om081308 on the other sticker does this help??? thanks rob
alldodge
Harness part numbers are
EFI 861157T 1
Engine Delco ALT 862179T 1
Engine Mando ALT 861819T 1
Wiring Diagram http://www.boatfix.com/merc/techbk/96/96hgd4.pdf
