I bought a 98 Four Winns Horizon QX last July. It's very clean and very low hours, and other than some scratches on the sides of the hull from loading or something like that, it looks nearly new. The gimble bearing and bellows were replaced a few years ago per the maintenance records, and are in good shape, but last night I decided to pull the drive just to verify and to grease the u-joints.
When I looked down the exhaust bellows there appeared to be something, almost like a flapper, about 2/3 blocking the hole. I used a 1/4" rod to push on the edge to see if it would open and it swiveled and fell out inside the exhaust box. I moved it around a bit and shot the pictures below down the exhaust bellows. After moving it around a bit, I'm convinced that it's a section of the hull that was cutout through the transom. It must have been in there since 1998, and it's amazing that it didn't completely block the exhaust port, preventing the engine from even running. It's amazing that the quality control at the Four Winns factory was so poor that someone could use a hole saw to cut the hole and not verify that the slug was removed, or at least that's my theory.
The question is, how do I get it out? It's too large to come through the transom assembly, and I really don't want to remove it just to get it out if I don't have to. Is there any way to reach it from inside, inside the exhaust box?
My thought is to use some sheet metal to protect the exhaust bellows, and then take a 1/4" rod, bend a hook in the end, heat it red hot repeatedly, and reach in through the bellows and see if I can cut/melt a slot down the middle of this piece until it gets most of the way through, after which it should scissor and collapse enough to be able to fit down through the transom hole.
Is this likely to work, or does someone have a better idea?
The boat has the 3.0 engine, M# 302CPBYC, S# T1307301, drive is M# 3868814, S# T0818545, which I think is the Penta SX-M.
Thanks for any suggestions/help
