1.32 :1 or 1.5:1...Which to go with?
chris650
Hello everyone. I started a thread just about the time the maintenance started on here, and it got deleted...so I will try again. Anyways, over the winter I replaced my merc 228 with a 260. Engine is running fantastic, still not in the boat yet. So my question..I have two outdrives I can choose from, my old mc-1 which is a 1.5:1 gr, or an R drive, which is a 1.32:1. The R drive is in much better shape then the mc-1, but im not sure if I can go with the 1.32:1 gr. If I did go with that one, what would be the differences? Or maybe one of you knowledgable techs can tell me why I shouldn't! Like I said, its in better shape then the mc-1. I also looked up info online and it says that it was a gear ratio that was used with 454 big blocks, but , this was a drive off of a 260.
HT32BSX115
Howdy,
1.32:1 will be WAY too "tall" for efficient prop RPM if you plan to run your engine at a maximum of say, 5100 RPM or so.
That doesn't mean it was "right" though..............
If I had 2 good Merc drives, I would clean them up, do a little painting and sell them on the market.
Then I would buy a new SEI 1.50:1 drive. (you'll likely have to "pony" up the difference of course...)
This way you have a nice new drive (with a 3 year warranty) to go with your nice "new" engine.
Either way, I wouldn't use the 1.32:1 drive with a small block V-8 in a recreational boat.
Regards,
Rick
thumpar
I like the selling idea. The 1.32 was used with the 454 and are hard to find so you might be able to get some good money for it.
HT32BSX115
If those drives are in fairly good shape, he may get enough to cover most of the cost of the new SEI drive.
