Captain Ollie West
- May 1, 2014
- 156
Nothing like taking it all with you!
I'm not sure how simply bolting/welding on hitch components raises the GCWR of your RV. Engine/gearing/brakes/suspension/etc all go into calculating that amount. Unless you got a spec sheet from Winnebago certifying that your alterations have increased the towing capacity, I'm not sure how well that would hold up in court, if it came to that.
It's not hard to up the 'tow rating' of a motorhome. I used to tow my 7200-or-so pound Sun Runner all over the place with my 27' Winnebago, which was factory rated to tow 3000 pounds. How? I had a killer hitch built and installed. It was actually 2 hitches, one of which was bolted way up under to the original Chevy frame, and a second hitch bolted up "normally" onto the frame extension. A piece of 2" solid bar was fit into both hitch's receivers and welded in place, essentially making them a single unit. The Winne already had air bags so tongue weight was no issue at all. I could've towed a freight train with that setup!
