Ummm, this guy is dealing with a tunnel hull. To get the most out of a tunnel hull, you need an adjustable jackplate. Yes, you can just set it and forget it, but that is like having a 4wd truck and never using the 4wd feature - IOW, why have a frickin' tunnel if you can't take advantage of it? They are hugely inefficient compared to a standard hull, so if you got it, you should use it to its full effect and at least get a little payback.
On my boat, and most all other tunnel hulls that I am aware of, you drop the jackplate to get a good holeshot, then raise the plate to either 1) run through shallow water, or 2) gain better performance while on plane, or both. You can't have both at one setting with a tunnel hull. The adjustable jackplate also makes a huge difference if you're varying loads a lot - i.e., your boat is loaded with people/cargo one day, and just you and a buddy the next day.
