Huntdakota
- Jul 9, 2014
- 3
Hi all. ok i froze the old stock motor, enough said and done. Ordered a new motor online after a lot of research! Boat is a 2004 so I decided to get a complete motor. That is everything is on the motor, new 4 barrel carb, exhaust manifold and risers, as my old is 10 years old and just thought would be better to get new. Only parts we had to swap are the starter, power stering and altinator. they said the motor was in their words SIM tested....iguess that means they spin it and check for leaks and commpression before it leaves their shop. So got the new motor and installed it.... the only adjustments needed are on the timing and the carb. Set timing between 8-10 and now is at 9 adjusted carb as they sent directions, new 4 barrel turn each side screw until motor runs faster then turn back 1/4 turn did on both sides and seems to be correct. The motor by the way is a 4.3 vortec V6 We have checked the fuel pressure and is good. ok my problem is....The motor runs great and idles great!! purrs like a kitten! Now start to give it gas and it sputters back, I baby the gas as I give more throttle and backfire! Only thing we havent tried to replace and have on order is a new ignition module? Is this my problem? Someone help This is a brand new motor and spend to much money not to be working!!
