- Jul 18, 2011
- 18,285
Hello Folks:
I've been having an intermittent problem starting up my Mercruiser 7.4LX MPI engines (see S/N's in my sig below). So, before I get going on diagnostics and possibly replacing 'stuff', I'd thought I'd post it here to see if anyone can provide some insight or experience with a similar problem.
First off, I have twin engines with the electronic fuel injection (multi-port).
Normally when I go to start them, I turn the ignition switch on . . . get a single 2 second beep from the 'warning' system . . . turn the ignition to 'start' . . . the engine starts and I get a second beep. Good to go.
Lately, when I go to start the engines, it seems like the ignition switch is becoming intermittent, as it does not seem to make the ignition system turn on . . . I do not get the first 'beep' and if I turn the key to the start position - Nada. The port engine began doing this a few weeks back, but now the starboard engine has joined the 'fun'.
So, far, if I try a few times, I will get the 'beep' and then the engine will start. Once they are running, it is fine.
Looking through the manuals that I have, it looks like I have the 'ignition switches', the 'kill switches' and also the possibility of a 20 amp fuse in-line with each ignition switch. Before I go throwing new parts at this issue, I thought that I would see if any of the Mercruiser Guru's on the forum can shed show light on the ignition systems for the EFI engines. In replacing the ignition switches, I'll want to get a matched 'set' so that the keys are the same for port/starboard
So, my questions:
- Since both switches are showing the same problem intermittently, would there be something else to consider? At this point, I am not sure if the ignition switches are acting up, or if it could be the kill switches . . . or even the fuses.
- Where can I find more information about the 'beeps' that you get from the starting/ignition system? My engine seems to be covered, in the Mercruiser manual #16, and it looks like I may be missing the second book. So, far I have not come across any information specific to the EFI/MPI engine ignition system.
- Anything else that I should consider? I figure if it were the ignition switches, I might have the engines shutting off while underway . . . :noidea: so far that has not happened, but I am wondering if the fact that they have not, if it is pointing to something else :noidea:
As always, TIA for ay help.
So, my questions:
