Am I Missing Something?
scatgo
Is there a gasket that goes between the upper and lower gear case of a Alpha one stern drive. Cant seem to find one online.
scatgo
Thanks but is that it??!!! What keeps sea water from getting into the drive? Or gear oil from leaking out from between the upper and lower???
stonyloam
That's it! A small quad ring that seals the oil passage between the gear housing and the driveshaft housing. That is why you fill the outdrive from the bottom. Parts of the outdrive are full of seawater (exhaust) but there are seals on the propshaft, shift shaft and gear housing shaft along with main driveshaft that keep water out of the gears.
That quad ring passage is the only way gear lube passes between the drive halves, so is very important to fill from the bottom and vent out the top. There is a hollow passage way around the shift shaft on the lower unit that also sees water. There is a drain hole for it as noted, you want to clean it out if you separate the drive. They tend to collect junk and get clogged.
On the left side of the impeller housing in the picture is another hollow passage way that allows water to drain around the bearing carrier which has seals around the it and also the prop shaft. That's how water gets to the prop when you run on muffs on the trailer.
