I have a OW380726 3.0 mercruiser. I am trying to remove the starter. I have unhooked the battery, the large term with the wire coming from the battery, the small term with the yellow/red wire. I then loosened the bolt on the bottom, the one to the right when in the boat facing the motor. The one on the left up against the flywheel I got loose, but it seems like it isn't backing out for some reason. I've been 1/4 turning it for about 10 minutes straight and when I fell under there the bolt is still tight to the metal. Any help???
