Pony
- Jun 27, 2004
- 4,355
I have a Huminbird 997c and a Huminbird 597ciHD at the helm, and both have low battery alarms. I had it set at 12.0 volts at the start of this season. On the first couple of trips, it never went off. My starting battery (which also runs all of the accessories) started to go bad sometime after that. Usually I never check that battery because the main motor keeps it pretty well charged unless I am really running a lot of extra stuff and not using the main motor a lot. I generally check in the driveway by turning the key to "ON" and listening for the beep and seeing the needle above 12 volts on the dash. At the end of one of the trips the low voltage alarm came on when I started the main motor to head back to the landing. I didn't think anything of it, sort of figured that the voltage dropped from the main engine starting. The boat sat a few weeks, and the battery was dead (could run electronics but not turn the motor over) when I got to the landing in the morning on the next trip. I did my normal key/beep routine in the driveway....which is now obvious to me not enough to think the battery is charged enough to start the boat. Clearly a sign the battery is not holding a charge correctly. I was able to run jumpers to one of the deep cycles to start the motor, and then ran it awhile to charge the starting battery....which it did....we were fine the rest of the trip. Next trip out, battery was charged the night before, and after a couple hours on the lake, the low battery alarm was sounding again....so i ran up the lake a few miles to charge it up.
I have now replaced the battery with a larger group 27 deep cycle, and have added a battery tender maintainer/charger that has a quick connect for when we get back home. The other deep cycles are connected to a two bank on board charger.....previously the starting battery was not on anything, With a good battery now, I doubt that it will drop to 12 volts on any given trip. I know that last season I had the alarm set to 11.5 volts, and I was able to start the motor on that when the alarm went off. I don't think that is an accurate reading as I doubt I could have started the Optimax if it were really that depleated.(That battery was replaced with a random starting battery I had laying around) I don't want to set it at 12.0 and have it going off all the time when the battery is really at 12.3 or something like that.
Do I set it at 11.5 or 12? under the assumption that 11.5 is really not 11.5 and proabably higher. The volt reading on the dash panel was close to 12 when the alarm went off at 11.5. Is this chart accurate?
