hello,
I am new to this forum, I just bought a 86 sea ray Seville, the oil mixed with the water, so the oil was milky white, I bought the boat cheap because of this issue. it has a 140 mercruiser. So first of all I did a compression test on the motor, 1-130 2-135 3-130 4-0, so after a little bit of looking around I found the exhaust valve stuck down, so I removed the valve cover, and I seen the milky white oil on the rockers.
So I sprayed some lube on the cylinder 4 exhaust valve and I got the valve to move again :happy:
Put everything back together and did a compression test again. 1,2,3, all the same as stated before, cylinder 4 was 150. (kind of high)
Changed the oil and put fresh oil in, ran it with the water on for about 10 min.
removed spark plugs again and all were good but cylinder 4. I removed the plug and had some water on it. I turned it over with the plug out and out shot some water.
So as of right now I am going to take off the riser and manifold, witch looks semi new, prev. owner said he bought new one from ebay a few years back. maybe gasket issue??
Just would like some info to make sure im in the right direction. thanks
