5.0 mpi mercruiser wiring harness question. I found a plug that was up against the manifold riser area and it was touching them. The plug is on the opposite side of the engine where the ECM is located. The harness has wires in it then goes into this plug that only has one wire and makes a loop and goes back into the harness. Anyone know what this plug is? Is it a ground wire or does it have power on it? I just replaced the plug. The harness wasn't hurt but the plug and wire were burned and melted. Thank for the help.
