PensacolaJason
- Oct 23, 2011
- 176
I ran my new (to me) boat this past weekend for the first time and after about 10 minutes at full throttle a solid alarm rang and wouldn't stop until we shut the motor off. The motor is pumping water through the telltale. After letting it sit for a while we could run the motor just above idle with no alarms, but as soon as i'd give it some more throttle it would sound the alarm. I pulled the thermostats and they look good to me. I pulled the lower unit and it had all kinds of mud and sand in it. The water pump casing looked prettey good and the impeller didn't have any cracks that I could see, but the prongs were definitely bent from use and would not straighten out. I have cleaned it out and am waiting for a new water pump kit.
I do have a confession to make. On Friday night, the night before I took my boat out, I wanted to make sure the motor would start and turn over, but I didn’t want to hitch it up to my truck just to move it over to the hose to put the muffs on it. I figured running it for just a minute without water wouldn’t hurt it. And that is what I did. After doing some research here in the forums, I have found that some people have reported that running without water for just a few seconds can warp the impeller causing it to pump water still, but to the point where it’s not strong enough to keep the motor cool at high RPM’s.
I doubt it’s a coincidence that the boat never overheated before for the previous owner and after I run it for minutes without water it overheats the next day. I rrealize that was a stupid move, but I'm wondering if this might be the contributing factor to my overheating issue.
