bayliner cx225 19' specifications
smtilford
Hello, i am trying to track down the specs on my 1984 Bayliner CX225 19'. I know that it has a aq225d motor and 280 outdrive. I am trying to find exact beam and length and width, weight. I plan on restoring it this fall, and want to mock it up in Sketchup 3D. Thank you for any help!
Hello, i am trying to track down the specs on my 1984 Bayliner CX225 19'. I know that it has a aq225d motor and 180 outdrive. I am trying to find exact beam and length and width, weight. I plan on restoring it this fall, and want to mock it up in Sketchup 3D. Thank you for any help!
Ayuh,..... Welcome Aboard,.... Take a tape measure, 'n Measure it,....
smtilford
Hey Bondo, thanks, I wrote that while I was at work, I was hoping to map some of the boat out while there. I just got done doing some measurements. I am still trying to track down information on this boat. I know that it is the Olympic gold medal capri edition CX225, that it is 19' with an AQ225D and 280 out drive. Byond that, I am at a loss. I think this would be the 1950 model? But I am unsure. If you could point me in the right direction that would be great!
oldjeep
From the pictures I could find online it sure looks like a 1950
Maclin
Regarding dive ID, if the "80" is correct then it will be a 280 drive, not a 180,
smtilford
OldJeep, Thank you, that was what I figured, but I wasn't sure. Maclin, you are correct, thank you, I will edit, I looked at the outdrive again.
