Okay, instsall the lanyard. Unhook the 5 pin amphenol connector again. We are going to test the switch with an ohmmeter.
So, put one lead of your ohmmeter on a clean engine ground. Put the other on the stator side of the connector on the blk yellow wire. With key off you want continuity. with key on you want no continuity. If the Key on test shows continuity disconnect the blk yellow wire from the m terminal of the key switch. Test again and report back.
Was supposed to work on the motor last Thursday but out of the blue my wife wanted to go boating / fishing. Took the SeaNymph down to Cheat lake in WV. Had a great day.
OK, blk/yellow wire checked good. Cleaned up some ground wires, mixed up a small batch of 100:1 premix. Hooked up the hose and fired it up. Lots of smoke. Might be because the VRO is still connected? Might still be burning off the fogging oil? Might be I originally had a tank of 50:1 hooked up when I first started it?
Seems to start and run pretty well for sitting as long as it did and the carbs and fuel filter not being touched?
I got a factory manual for it, very well written and illustrated compared to the Tohatsu and Suzuki manuals I've tried to interpret.
From what I can tell, the boat needs the transom rebuilt (orchid shaped mushroom growing out the back) and it must leak. I see where the PO dabbed some silicone based stuff around some rivets and seams (bow area).
I think the next move is to get the motor off the boat. I think it will be a good motor?
I'm not planning to get crazy with this restore. With your help I think I've determined that the motor is worth at least tuning up and cleaning up? Any comments to this regard still welcome?
If I can get the transom replaced and the leak(s) fixed that's enough for this year. I'll probably tinker some with the motor over the winter.
If any of you have any experience actually replacing a transom on this model boat, I'd love to hear from you?
I've followed many threads where the guys tear the boat apart, buy lots of new tools and fancy electronics with great pictures, then the thread dies?
I'll be opening a new thread in the Restoration section and I hope you'll add your advise.
Trying to post some pictures and I'll post a video of the motor running later.
thanks again.
rob
Click on the picture to hear the motor run, not the link below.
