turbocorrado
- Aug 14, 2013
- 251
97 wellcraft eclipse, has the back to back seats that are supposed to pull out and lay flat..... but i cant figure them out, how are they supposed to work?
Pull up then out should have a leg that comes down. If they are like most back to back seats got photo?
How do you know if you have not moved the seats yet?
Can you lift just the ends? Or can you lift the section where the backrests are too? If only the ends move up a lot and the backrest section seems to be tied down then I bet there is a tube on the bottom of the backrest fitting into a spring steel bracket, and if so then you need to move the top of the backrest forward to get the tube to pop out of the bracket first.
