Woodonglass
- Dec 29, 2009
- 25,930
Looks Like a WINNER 2 Me!!!!
One negative might be that the boat in the pic is a noreaster style with a forward helm/cabin, yours is a mid helm/cabin so if u run the cover overhead of the seating, you cut way into the cockpit space?...it may not look quite as quaint....and more like a sampan from Vietnam....maybe a photoshop mockup to see how it looks on urs....
You may have to get yourself one of those cone hats, or even a Devo hat!
http://www.mekongtourisme.com/images...ess_Cruise.jpg
I do like the idea tho!..and should be relatively easy to make..
http://www.mekongtourisme.com/image...Dong_Hiep_Hoa_With_Cai_Be_Princess_Cruise.jpg
Major lol!
Thanks for the link pic. You are such a good Crapper!
Think when I get to it....very soon now that I have weather I'll make a physical template from foam board for some prototype iders.
Mike that's a GIVEN! Start playing yet with your berth ceiling? temps starting to get real good hear. Going DARK myself real soon inside the boat. LONGER DAY LIGHT!
That's a good idea, then you can work out things like roof pitch and size. Might need to be more slanted than with the westeaster....being set back and all.
Well got to at least glass off 6 of the 8 boxes and cut the rest out for the other 2. Running out of the green stuff. Even the EEEpoxy is getting low. Should have enough thought to finish the boxes. Then Give the boat an entire SPRING Cleaning and start to prep the rest for later. Been running crazy.
