Have a 2002 four winns 298 with twin VP 5.0 GXi with DP outdrives. Intermittently, when I try to fire the STB engine, I have a dead key. The fuel pump will initialize and the engine alarm will beep, but nothing when I go to fire the engine. Things that I have tried when it happens: jiggling the throttle to make sure it is neutral, check all connections on ignition switch, pulled apart throttle to check wires, Swap out relay with spare on engine fuse panel. All of the sudden out of the blue, it will fire up, completely randomly, and not linked to anything I try above. It happens very intermittently, probably three times so far this season, but once it forced me to limp home on one screw. 20 minutes after I docked, the darn thing started, without any pattern. Where should I start my diagnostics?
