Ok, here's a quick way to test, if you have a spare coil, lead and spark plug. (and a 555 timer chip kicking around)
Pull the module out. Set it up with the coil and a 12 volt line coming in. I would set up a 555 timer with a 50% duty cycle so I could adjust the 'revs'. Have the white/green wire from the module go to the 5 volt point of a voltage divider. The output pin of the 555 being the 12v source for the divider network. Use a pot on the 555 and run the 'speed' up and down. This will confirm the module, or not.
Chris....
