Woodonglass
- Dec 29, 2009
- 25,930
Well there's been a LOT of glass boat with Leaky tanks and I've never seen the gas eat thru the hull. Just not gunna happen. Just like the pour in foam, gasoline just won't affect it.
If you mean to use glass to fill in the pits I would not do that. If anything use something like JB Weld or similar. If gas comes in contact with glass it will eat it up.
My concern of an epoxy/glass laminate versus epoxy spot repairs/fills . . . The thermal expansion properties of the two laminated materials is probably quite different. It would seem that for a large area there could be separation of the laminate at the edges over time due to these different thermal properties. The separation of the laminate will then create a nice crevice for water (moisture) to collect and cause corrosion of the aluminum.
More theory than experiences to draw from as I have stated, but that would be my concern.
I would think that spot repairs (i.e. filling the pit areas with epoxy) would be preferable to a complete laminate due to the thermal properties
And...a sucker for researching issues such as this, I spent some time last night "Googling" and found that the general consensus seems to be that epoxy coatings on aluminum are "If'y" at best
Since Jigngrub isn't here any more to "say it how it is", lol... If you insist on doing all of this work and willing to remove the cap and deck to replace the tank in 5 years to save $500 and don't plan to smoke, grill, or light a flare... My experienced opinion is this...
You must prep and condition the aluminum, new and especially used/corroded aluminum to epoxy coat. In addition to sanding. PPG ...
http://www.bapspaint.com/docs/psheets/PPG/Automotive/Deltron/P-226.pdf
You can research the particulars.
Laminating cloth onto a gas tank is silly and is going to cost more than a quart of paintable epoxy
Please don't be offended. I've been called out and straightened out on my build as well. Keep up the good work!
