About 6 months ago we upgraded from a very light Stingray to this Wellcraft Excalibur, it's a 1999 with a 5.7L (carb). Freshwater lake only boat, trailer is newer but fair (under-rated so local/ storage use only). Engine just had new bellows done, I did the Impeller, unknown amount of hours (no gauge), everything works. Runs a bit over 50mph and has great performance! We like the size/ layout.
It required ALOT of detailing (exterior) , wetsanding/ buffing, about 20hours worth but came out looking great! has some scrapes in the gelcoat here and there but for a white boat you don't see much. Inside is great except for 2 slight tears in the buckets where the seams/ stitching is pulling out, about 1" in each seat. We put in a kicking sound system and new speakers + Sirius Radio dock.
My biggest concern, I discovered after owing it-it has a slight list to Starboard, about 1" lower than port when parked in the slip on a calm day :cold: Everywhere I check it appears solid as can be but I can't see under the molded fiberglass floor much since it is one piece. from the ski hatch/ engine compartment it looks like it's spray foam filled insulation/ flotation but I can't see much other than that. The cockpit drains work right but this does make it a nightmare to load on a trailer since it sits ever so slight crooked unless I do some work to get it straightened out (back trailer WAY in, use engine to reverse starboard to hop the boat over). I don't think I'm going to open up this can of worm.
We paid $9,500 Should I feel comfortable with this? I'm always scanning the options out there and unfortunately I've seen a few better deals that have me re-considering my prior good feeling of a good deal.
