- Mar 8, 2009
- 42,984
Start looking for plywood the other day and came up with exterior BC plywood. In WOG's thread it mentions Aruaco Plywood and MDO. The Aruaco comes out to be ACX exterior plywood. The ACX tells me it has one side which is grade A, one side grade C, and the middle being grade X. MDO is exterior grade and is the first choice of sign painters, but it does need the edges sealed to keep from water penetrating.
That said all the plywood I use will have edges sealed with resin. The BC looks to be a better option then the ACX because it is grade B on both sides, and grade C on the inside layers. Did I miss something in the translation?
