bruceb58
- Mar 5, 2006
- 30,799
Typically, they aren't even screwed into the block. They are screwed into a brass elbow which is then screwed into the block. Plus, you are in fresh water!
If they are screwed into the block, you need to remove them to drain the block so just leave them out for the winter!
On some engines, the knock sensors are screwed into a fitting and don't even see the coolant passage.
I want to see the pictures!
