Nice transfer from one trailer to the other, good thinking I would never have thought of doing it that way, nice looking trailer, boat sits nice and low in it, I like the bunk work.looks good.
Smooooooth trailer transfer....you make it look like you've done this before :lol:
I really like that bunk design glen!
What is the lowest pressure the staple gun will run on?
Fit a plastic spacer over the tip, maybe?
I would try cutting the length of the driver down a little at a time. Sounds like it may be protruding to far and doing the damage instead of the power being a problem.
My old electric Duofast will cut the vinyl if I press too hard.
Just thinking if you put a spacer or cap that held the tip away from the vinyl material it wouldn't cut through each time.
Sometimes I've seen staples driven through a heavy paper strip. I guess so the staple doesn't cut into the work. I wouldn't use paper on a boat, but maybe thickish plastic you staple through might work. Like pieces of the lids on coffee or Pringles cans?
Post padder!
Did the staple cut through the plastic "straight edge"? If you reply, back to an odd number until 6000. :lol:
Dozer is our newest Vice Admiral @ 5000 posts. Congrats, DII
No promotion at 5000?
Baboooom! 5000 posts of awesomeness! Congratulations!!!![]()
Woot! Congrats on the promotion Dozer, what are you going to do with the salary increase? :lol:
