- May 16, 2009
- 9,167
The older EFI Merc big blocks are known to run more on the richer side and having some carbon build up like that under the heads is kind of on the normal side of things.. honestly. Just read some of your spark plugs more closely to help let you know what's going on. Especially since you have a clean start now.
With the older MEFI ECM's both standard and closed cooling systems/ stern drive or MIE engine models used a 160 degree thermostat so there was no ECM adjustments really. The use of a 160 or 170 thermostat and different ECM's for either cooling system really started in 2001/2002 when Merc went to the 555 ECM's.
Mercruiser recommends the use of a case ground on most of their sensors. Some info found on posts 33 & 34 might help here.http://forums.iboats.com/forum/engi...a-water-pressure-sensor?p=8856906#post8856906Maybe I need to go back to school here but a ect is merely a resistor that is heat senstive in this case it resist's based off temp a 5 volt signal is sent in and 3 goes out hence your temp....I cannot see how grounding the housing would be any part of the circuit.
