Re: gm 3.8l 239 valve adjustment
Adjust valves by backing off adjusting nut until lash is felt at the push rod, then tighten until lash is removed (try turning push rod with your fingers) then tighten adjusting nut one full turn.<br /><br />With #1 cylinder @ TDC, Adjust intake on 1, 2 and 3. Adjust exhaust on 1, 5 and 6.<br />With #4 @ TDC, adjust intake on 4, 5 and 6. Adjust exhaust on 2, 3 and 4.
