San_Diego_SeaRay
- Nov 9, 2014
- 343
I have a 1981 Mercruiser MCM 260 engine that I need to buy an alternator for. When I search for a replacement, seems as though I have some ?upgrade? options available to me. I don?t know what the output of the original alternator was, but here?s what I?m finding as plausible replacements (the original was a Motorola 3 wire):
Here are some questions I have and hope someone can help with:
JC
- 3 wire 63 amp
- 3 wire 63 amp w. (4[SUP]th[/SUP]) tachometer wire
- 3 wire 105 amp
- 3 wire 140 amp w. tachometer wire
- Other than the cost, are there any drawbacks to getting the higher output alternator? Do they produce too much amperage at times? Or would you pretty much always get the higher output if cost wasn?t an issue?
- I was under the impression that the tachometer was usually hooked up to the coil, and that?s how the RPMs were derived. Is the tach wire at the alternator really an added improvement?
JC
