engine mount bolts
betayv
hello guys 1987 350 searay alpha one, engine is out and I need to replaced the bolts located on the back of the engine the ones attached to the transom assy, the old ones were striped any diagram that I can use thanks.
Bt Doctur
Need to clarify what bolts.
San_Diego_SeaRay
No Title
OP: Are you referring to Part #1 and the associated hardware?
If it is, it seems to be OEM: # 10-97934A1 but someone more experienced should verify that.
Ayuh,.... Part numbers 1, through 6 are Mercrusier specific,......
achris
More fish than mountain goat
#1. Screw, transom housing to flywheel housing. 10-97934
#2. Washer, aluminium. 12-35777
#3. Spacer. 23-99299
#4. Washer, fibre. 12-32834
#5. Double wound lockwasher. 13-33734
#6. Nut, aluminium. 11-863332
HTH,
Chris..........
