BassinAround
- Feb 11, 2015
- 3
HI everyone, I am new to the forum. I ahve a couple of questions and hope you all can help me out.
I have a 2009 Stratos with a Motorguide 82 lbs thrust trolling motor. The trolling motor has around 150 to 175 hours on it and has a foot pedal. I had the prop for the trolling motor come off the spindle in the water a couple of months ago and haven't used it since.. I replaced the prop with a new one that came with the boat (same size). I took the boat out couple days ago and trolled for around 2 hours. I had no issues until the end when I stopped getting power to the trolling motor. My setup is 24 volt series batteries which were just replaced 7 months ago. I have a toggle switch installed in the hull for on-off to the trolling motor. It also acts as a circuit breaker. I replaced this thinking maybe it was the switch today. With no luck I still do not have power to the trolling motor. I checked all of the wiring under the foot pedal and in the top of the trolling motor. I also checked the connector in the bow which still looked good. If I turn off the toggle switch on the foot pedal and turn the circuit switch on in the rear (hull) I have no issues. When I turn on the toggle switch on the foot pedal it trips the circuit switch in the hull. It has to be grounding out somewhere on the trolling motor or the toggle switch on the foot pedal is bad. Has anybody else had an issue like this? Also any direction on what else to look for is appreciated.
