agallant80
- Oct 25, 2010
- 2,328
Some of you may remember last year my bilge was filled with gear lube. I went ahead and replaced the fitting that I think was leaking(22-861163 QUICK CONNECTOR) but if its not the fitting than its the Through transom fitting (22-861150T02 - FITTING ASSEMBLY) which from what I have been reading is a mother to replace. Replacing the Quick Connector was enough of a PITA for me.
My question is is if it is the through transom fitting that needs replacing can I just delete the Reservoir system? I don't know how I would do it, perhaps just as easy as take the drive off and snap off the fitting on the bell housing that pushes up against the ball in the bravo.
Is the lube system really necessary or is it just overweening. Did it ever solve a problem?
