Ayuh,..... Ya need more fuel at high rpms, so I'd try smaller needles,....
Needles are easy to change, verses changin' the jets,...
I definitely have a lot to learn working with the edelbrock. One thing I'm uncertain of, how do I tune it not knowing air/fuel ratio?
This is a great guide. I will most likely need to do this same procedure, along with swapping from a 305 to a 350. I have a 93 Starcraft I purchased and winterized last fall. Started up fine, and no water in the pan. Ran it between 800 and 1000 on muffs, and changed the oil. Saturday I replaced the impeller, and plugs (all look good, but a bit oily (betting from fogging), now there is about 3/16" of water on the dipstick. At the marine shop right now. I should know by Saturday.
If you don't mind me asking, what did the project run you? I am thinking the same route you took, tools, new carb, intake, exhaust, etc.
Again, you should be proud, you did a nice job.
That's kind of interesting as this one is also listed for the BBC. I don't know my big blocks well enough to know the differences in the starters.
Ayuh,..... Basically, Chevy Starters, are like the bellhousin' bolt pattern,..... They're All the Same,...... with some variations,....
2.5l, to the monster BBCs,.... They come in 2 basic flavors,....
The straight across bolt pattern is for the 12" flywheel, on Any of our Chevy motors,....
The staggered bolt pattern starters fit the 14" flywheel, on Any of our Chevy motors,....
'n of course, diameter flywheel is determined by the available block drillin's for the Starter,.....
Ya gotta Love Chevy motors,..........![]()
Whew I feel alot better now reading this post. I just purchased a 1998 2350 Bayliner Capri with a cracked 5.0 and now I feel alot more comfortable about doing the swap. The guy threw in a 1999 Vortec 350 block so I just need to transfer everything over and drop it in. I do have one question, did you swap the stock cam out of the 5.7 or keep it!?
I would probably suggest a new thread.
