I am new to the boat world, I traded off my old Harley for this 94 stingray. I was told it needed a starter and a sea pump. Was told it quit pumping water and was shut down immediately. I have replaced the parts and I am about ready to fire it up. I am wondering if the sea pump on the engine is the only one or if there is some kind of intake pump in the outrive. also I have found that when I shift the boat to forward or reverse, it is not moving the shift lever on the motor. The lever can be moved by hand which is engaging the prop but the cables don't seem to be functioning right. Its a mercruiser 454 big block, bravo one out drive. recap of the issues:
1. looking for a little explanation of the water pump system prior to firing it up with the new pump
2. shift cables not engaging the shift lever.
Thanks in advance! hope I have provided enough information
