Greetings All!
I got a free 1977 Seaswirl about a month ago and have been going through it to get it "sea-worthy" One of the issues I had was the tilt not lifting the drive. I pulled the tilt motor and it was fried so I put in a new one. The new motor seems to work fine, it will lift and drop the motor. The problem is that when I bring the motor down, it comes down hard and seems to jam up on the quadrant gear. I will hit "up" and I can hear the solenoid click but the outdrive wont budge (not even if I lift while someone else hits the switch). If I remove the quadrant and manually lift the drive a little and re-install the quadrant, it lifts right up. Has anyone else had this issue? Is it just a matter of lowering the drive in small increments so that it doesn't hit so hard? Perhaps a clutch adjustment? Another gasket on the clutch cover? Any help would be greatly appreciated!
Thanks! Mark
Thanks! Mark
