Cowhune
- Jul 10, 2012
- 37
Jealous on the progress, just saying, not hating. Looking good cowhune. One question though. I was planning on wrapping my deck with carpet then laying it in (after sealing ofcourse). So its wrapped and tight. any reason you put the deck down first then gonna cover it? Maybe its something Im missing in a step I need to consider.
Well, simple answer: that's how SC did it with the vinyl. Furthermore, I'd prefer to have one solid run of carpet rather than having seams at each piece of wood. If you were to wrap the wood, you would also have to make adjustments to your cuts to compensate for the thickness of the carpet when butted against each other.
For the most part the edges will all be covered. The only edge that is visible is under the consoles I believe. When I reinstall the side panels in the boat I will fasten them down through the carpet into the floor which should hold it nice and tight.
P.S. Nice tools! I'm also jealous.
