San_Diego_SeaRay
- Nov 9, 2014
- 343
Hello All
Gonna rebuild my wiring harness on my 1981 MCM 260. Gonna splice everything into the cannon plug and that's all I'm keeping of the old harness.
But I want to make sure I understand how it works so as not to create an inferno on the water with my handy work. Specifically, I'm looking at the purpose of the circuit breaker in the attached circuit.
Here are my observations:
Is this what's going on? This is just a wild guess on my part. Do alternators create higher voltages, or do they have some way of just creating higher amps w/o creating higher voltages?
I'll have some follow up questions but I need to first understand what's going on here.
Thanks,
JC
EDIT: OK so the alternator should never really produce more than 14.XX volts. So there goes my theory. Sigh.
- The red/purple wire coming off the Alternator is the sense wire (correct?)
- It is wired to one side of the circuit breaker
- The circuit then continues to the starter terminal to which the BAT+ is also connected via a heavy gauge wire from the battery +
- The sense wire receives it's required voltage "signal" from the BAT+ via the starter terminal (typically just over 14 volts)
- If the load on the battery increases, the Alternator responds by increasing amp output (and voltage output increases as well) to the "+" on the battery
- If the voltage at the BAT+ terminal on the battery is 14.2 volts or something similar, everything works fine
- However, if the voltage at "+" battery terminal increases, let's say to 18 volts, the voltage at the starter terminal also increases to 18 volts
- In turn, the voltage delivered to the sense wire is now 18 volts
- Per Ohm's law, any increase in voltage must produce a corresponding increase in amperage
- So the amperage to the sense wire circuit increases as well, which should trip the circuit breaker
Thanks,
JC
