bmowers
- Nov 19, 2012
- 65
2008 Bayliner Br175, Alpha One, Gen II
Hi boaters, I just successfully completed an Impeller change and drive pull on my boat and with help from this board got it all together and working properly especially the cooling going through the transom exhaust ports. At any rate, I took the boat out today to shake it down and I am glad that I did because immediately I could tell that the boat was yawing to the right. Alot, like 20 degrees or so. I took the trim zinc off three times in the course of removing the lower that I did not mark it as suggested in the manuals. (note to self for next year) This is my bad. Now I was thinking that if the boat is yawing to the right then I should move the trim zinc to the right. Does anyone know for sure?
Thanks Brian
Thanks Brian
