Sea Rider
- Sep 20, 2008
- 12,345
Needed an alternative powering system to combustion engines to power a sib/rib used to follow rowers at a close albufera, which has banned traditional 2 & 4 strokes outboards. So deciding going green tested a Torqueedo 4.0 electric OB which is the top in the portable range. Although is equivalent to a 8 HP has the torque of a 9.9 HP OB. A Sea Rider 320 heavy duty sib inflated to 3.5 psi and keel to 4.0 was used for the test.
The standard prop delivered with engine produced at wot just 13 Km/h with a 220 pound driver, installed the biggest available prop and miraculously the speed topped 21.00 Km/h which is the minimum speed to follow a team of good shape rowers on 4 & 8 row boats.
Pros :
-Very silent.
-Low weight.
-Forward & reverse on throttle grip. Just twist grip right or left.
-Computerized monitor on throttle body.
Cons : compared to an OB :
-Lacks fast hole shot, need to move batts and driver up front to plane faster.
-2 sets of lithium batteries that weights 50 Kg are needed to output 48 volts.
-Bulky, occupies 1/3 of sib.
-Too much electric cable hassle to deal with.
-At top speed batteries don't last that long.
-9 hour charge per battery, need 2 chargers.
-Quite expensive, total package cost will draw buyer's eyes, ears and nose as well.
Down issue :
Although middle and lower leg has a straight sharp edge to cut water flow nicely, OB lacks a small water deflector plate to divert water climbing through leg against water wake, this produces unwanted tail drag which slows a sib/rib a bit.
Next week will test same electric OB on a 340 Rib which has less hull drag compared to a 320 sib, this time will compete against a 4 rower boat to see who's faster. Who will win ?
Happy Boating
Pros :
-Very silent.
-Low weight.
Down issue :
Happy Boating
