Wow! High praise indeed! Thank you, sir.. This is the absolute, SPOT ON, way to do an OTR transom. Very, Very, Nice job. Just remember the inner plys are not treated sooo, If you poke holes in it. you MUST use some marine sealant on the holes and the hardware to protect from water intrusion.
Okay, I'll get it done.I think I used one of those vinyl bolt thread covers and put a zip tie around it to hold it on. Either way is fine to terminate that thing.
Yeah, I meant "tearing" as in "eager to get started" on the carb cleanup. Having never taken a boat carb apart before, I'll definitely take it easy and only do one at a time. Documenting as I go.Yeah careful "tearing" those carbs apart, they can be fickle little demon pots if given the chance. Rather than tearing them apart I suggest a methodical break down and a thorough removal of the old gasket material. Don't mix up the parts for each carb either only put them back together with the parts that are from that specific carb. Leave the jets alone and just blow them out with compressed air. On my carbs the bottom drain plug on the main jet reservoir does not have a gasket that comes with the kit as it has no lip, I had to seal them up with teflon tape. Are you planning on using chem dip for the carbs too? If so make sure no plastic parts go in that stuff.
Remember too if you pull out the idle air screws to clean them, you'll have to set them at base 1-3/4 turns out and then adjust them again on the water with the motor in gear on the trailer.
Also replace all of the old fuel lines with new and use hose zip ties to secure the new lines. You don't have to use marine rated below deck low permeation fuel lines either, regular automotive fuel line is ok.
I think I may need a new float bowl because the inside corrosion lines up perfectly with this corrosion spot on the outside of the bowl. I'm a bit concerned that it's going to leak at some point.My carbs were spotless compared to those ones of yours that had standing fuel left in them to varnish. Scratches in the float bowl, why would you need a new one?
Yeah the Chem dip is pricey I guess but you get a gallon can of it and it's useful for all sorts of other parts cleaning not just carbs.
You can make that brass shine by using that ketchup trick or cleaning vinegar should take that corrosion off.
