Check the reverse lock, looks to me like it was staying engaged.
Man oh man, what a job you and the crew did on that boat. I've only checked in a couple times but I've read the entire thread and I'm not sure what I'm most impressed with, the work on the boat or your perseverance. The boat really looks good.
The 2 of you were pulling on a different axis, when you were moving side to side and the motor was moving, so was the steering ram. My 115 Merc with new SeaStar NFB helm and cable moves too, maybe about half as much but there's always going to be some play in the cable steering, only hydraulic won't have play like that. Test that out by turning the wheel and see how far it turns before the motor starts moving. Then have the boy take up the slack with the wheel and when the motor starts to move have him hold it tight then do that side to side test again and see what happens.
If that pivot point on the motor is worn out that would surprise me, it's greased steel in there.
The up and down axis, yeah those rubber bushings are compressed and worn out but it's not what's causing the steering play.
Glad you don't have to tear your motor apart to get to the swivel that's not worn. :joyous:
So when you put the cowl on the motor bogs but without it on the motor revs just fine. Have you done a link and sync procedure following the instructions for your motor and go over it to a T?. The cowl should not restrict air flow into the carbs, does your's have an air flow opening in the back top where the grab handle slot is on most motors?
Also the idle air mixture has nothing to do with your issue of bogging down as the main jets take over from the idle circuit after advancing the throttle.
We're working on it now. How do I get the bushings and spacers out? I removed the outside bolt and the inside locknut but that's as far as I can go. I thought that I might be able to pry the stud out, but that didn't happen.I would use a transom saver motor toter or something similar to prop the motor in place but that motor shouldn't be so heavy to where it can't be tilted into place when you replace the bushings and put it back together.
