scout-j-m
- Jul 31, 2009
- 643
Ok, I finally have somewhat of an update. I was able to pull the flywheel today after work, and with very little hassle too. The flywheel, magnets, and key all looked good. However, to me, the stator and trigger both looked not so good. The trigger has a visible crack in it and the stator appears to have melted areas. I attached some pictures so you all please give me your thoughts on the condition of both.
Stator/trigger issues aside, I went ahead and removed them both and also removed the cd module plate with holds the cd pack, coils, and rectifier. I plan to remove the fuel lines, starter, starter relay, carb, intake manifold and reeds next. In the service manual that is all that is said needs to be done before begin to unfasten the powerhead. Any tips or recommendations to do otherwise?
