Putzaroni1
- Oct 20, 2012
- 108
So I've gone through this forum and everything else I can find but am just not getting this.
I found Joe Reeves' instructions as follows:
(Manual Starter Cord Installation)
(This pertains to the vertical type of Manual Starters such as the 9.5hp and later 4.5/6/8hp models etc)
(J. Reeves)
1 - Have a pair of vice grips handy set so that they will grab the top of the starter spindle tightly but will not damage it.
2 - Using a large screwdriver inserted into the top of the starter spindle, wind the starter in a counter clockwise direction 12 to 14 turns, stopping so that the cord locking slot is facing the away from the engine.
3 - Lock the spindle in that position with the vice grips, letting the vice grips lay against the flywheel.
4 - Insert the cord as needed and make sure it is retained properly at that slot.
5 - Feed the cord out the starter cord hole at the front of the engine and attach the handle.
6 - Grip the cord tightly so that the spindle cannot spin around rapidly, then release the vice grips.
7 - Allow the cord to be withdrawn slowly around the spindle.
I had the starter off to replace a broken Leaf behind the intake manifold but upon reassembly, when I get to step 2 of Joe's instructions, It doesn't feel like the spring is catching or hooked in properly. I dropped the spring retainer plate down a bit to get the spring to go into the slot. I can't tell if it's catching or not but by eye it looks about right. I tighten the 2 lower bolts and try turning the spindle counter clockwise for 12 turns and it doesn't have any kind of recoil or back pressure.
Any suggestions on what might be wrong ? I really want to see if the leaf fixed it but need the starter working to test and use it.
Thanks.....
(J. Reeves)
Thanks.....
