MikeDobbs
- May 8, 2015
- 205
Hey Everyone-
So, I just finished a bellows rebuild and water pump service on my alpha gen 2. When reassembling the drive I was very careful to keep the little shift lever thing in the forward position (as well as the throttle and shift cable from the boat side). I held the prop to lock the shift lever in place, and put the leg on the boat. After the leg is fully mated with the bell housing, the propeller is STILL fully locked- so I know I am not allowing the shift lever to move.
BUT, when I let go of the prop, it falls into neutral. The prop spins either way freely regardless of where I place the shift lever in the cockpit. So, what's going on here? The only thing I can think of is that on the bellhousing side- when I was doing the bellows I removed the shift pin thing to clean it and grease everything. Is it possible I pushed it up too far before tightening the set screw?
Any help would be appreciated.
Thanks!
Thanks!
